HOLLY AND MARTIN HZ8864 METAL AND GLASS SLIDING DOOR DISPLAY CABINET 68.25 X 30 X 12.5 IN.
'Slide to the left slide to the right with this sleek transitional style exhibition cabinet. Four static shelves parade your treasured trinkets; the gliding glass doors reduce exposure of said prized possessions to dust or small hands. Two subtly playful round finger handles prevent prints on the glass and anti-tip hardware combines with a sturdy T-bar base constructing safe stability. Proudly show off your collections awards and accomplishments anywhere in your home with this easy to match distressed black curio display cabinet.
Features- Distressed finish will vary giving each piece a unique look
- Two-way sliding door encases treasures
- Features 4 fixed shelves
- Anti-tip hardware and T-bar base for stability
- Transitional style
- Black with silver distressing
Specifications- Materials: Iron Tube Iron Sheet 5mm Tempered Glass
- Assembly: Required
- Shelves Dimension: 28.75 W x 9.75 D x 9.25/10 H
- Clearance Dimension: 23.75 W x 9.25 D x 5 H
- Supports Up to: 4 lbs
- Dimension: 68.25 H x 30 W x 12.5 D
- Weight: 42 lbs
Price: 623.99
